Ga door naar hoofdinhoud
The Sega Game Gear portable gaming device was released in 1991 in competition with the Nintendo Game Boy.
41 Vragen Bekijk alle
Using a US Game Gear model in the UK?
Hi,
I have a US GG model (2110G) which states to use the 2103 AC adaptor only which has;
INPUT: 120V AC 60Hz 14W, OUTPUT: 10V DC 0.85A.
My UK charger has the following details;
INPUT: 100-240V AC 50/60Hz, OUTPUT: 9V 1A.
Is it safe to use this Game Gear by using the UK plug?
Thanks
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @beenz,
Assuming that your UK adapter has a DC output (you didn’t specify) it won’t harm the device.
It can operate on 6 x 1.5V AA batteries (9V) so it should work
Also verify that the plug of the replacement adapter is centre pin +ve as shown on the adapter case, (see image below of your USA adapter which shows the +ve goes to the centre spot of the circle - the circle represents the plug - inner and outer connectors).
If the UK adapter has a reversing plug attached at the end of the cable i.e. it can be flipped over to supply either +ve voltage or -ve voltage from the adapter, depending on which way it is attached to the cable, ensure that it is supplying +ve to the centre pin of the plug.
(click on magnifying glass symbol in image to enlarge for better viewing)
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Hi thanks for your advice, have just came back onto this site and seen your answer
door
Voeg je antwoord toe
Graeme Bentley zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 14
Altijd: 193
