Ga door naar hoofdinhoud
Released in 1999, the Braun Exact Power EP100 is an electric beard and mustache trimmer. It has an internal rechargeable battery.
3 Vragen Bekijk alle
hair trimmer cut hair very short period, WANT TO CHANGE BATTERY
Type and capacity of battery to braun ep100
What volt
What watt
What mah
update
Great thanks for all who help me
update
Please if possible
Answer on one more question
Very important!!!
What capacity of battery must be in broun ep 100, there is 1 battery, but
What capacity?
500 mah or 1000 mha
Very important
Great thanks
Is dit een goede vraag?
Score 2
3 opmerkingen
One of the clearest and most direct questions I've seen asked on Answers in my time here.
door
The higher the maH the longer it will last on a single charge.
door
the person who wrote the how to guide also said he used a higher mAh battery and his charger didn't last so long. something worth considering
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
http://forum.eserviceinfo.com/viewtopic.... I found this link to how to get to the battery (page 2)but couldn't find what exact battery was in your trimmer. You will be able to find that by taking the trimmer apart and then matching it up after. good luck
Was dit antwoord nuttig?
Score 7
2 opmerkingen:
+ for finding out how to change it
door
Yes indeed--I looked for some time with no luck. +
door
That wasn't easy to find but you need - (3 AA-size, 1.5V)
http://www.braun.com/global/male-groomin...
I'd also get a battery charger and rechargeable batteries like this one: http://www.google.com/products/catalog?c...
Score 5
3 opmerkingen:
Good research on your part also. +
door
Only the EP 15 and Allstyle use the 3 AA size batteries. the Battery on the EP 100 is soldered to the logic board
door
Very good OT, I missed that.
door
Well here is a replacement R17 AA NiMh Battery With Pin Tabs 1650 Mah 1.2V Battery Measures .559" x 1.97", 14.2mm x 50mm Fits Braun Models: Action Line, EP50, EP60, EP80, EP100, 540, 570 from here http://www.electricshaverstore.com/get_i... and here is the service documentation. The EP100 actually is a Braun 5601
Score 3
3 opmerkingen:
+ nice searching
door
+ You have a plethora of resources.
door
;-) Could not fix some of my old "stuff" without those resources. I actually purchase and repair according to the manuals I can get, makes my hobby easier.
door
Voeg je antwoord toe
IGOR zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 15
Altijd: 6,273
