Ga door naar hoofdinhoud
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
20 Vragen Bekijk alle
iPod classic cylindrical redundancy check
Tried restoring ipod classic, in both restore mode and disk mode ipod freezes on do not disconnect screen and itunes recognizes it, prepares for restore, and then ipod disconnects itself from computer. Computer recognizes "apple ipod" drive D:\ but the volume cannot be populated. tried right clicking file folder and formatting without success. Tried fdisk, got error "cylindrical redundancy check". Even tried active killdisk and got "device not ready". I also ran a test on the hard drive which did not report any bad sectors. Any suggestions?
Is dit een goede vraag?
Score 1
1 Opmerking
My suggestion at this time would be to remove the drive and check it separate from the computer. You can do this by using a USB-Zif adapter. It does sounds like a bad hard drive or hard drive cable to me.
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
When a storage device fails its CRC check, the drive is most likely failing... See if you can test the drive, or you should get another one (HDD, that is)
Was dit antwoord nuttig?
Score 1
Try different computer and/or firewire
http://forums.ilounge.com/windows-ipod-d...
Voeg je antwoord toe
Bryan C zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,899
