Ga door naar hoofdinhoud
The Sony Handycam FDR-AX33 is a palm sized camcorder that combines 4K video with video stabilization. It was released in March 2015, and was the first camcorder to introduce the new Balanced Optical SteadyShot (BOSS).
How to fix E:61:10 flashing error in my Sony FDR-AX33
E:61:10 flashing error in my Sony FDR-AX33 I dropped it once.
Is dit een goede vraag?
Score 1
1 Opmerking
If I need to replace the steady shot assembly, where can I get this fix near me in Mansfield, Ohio. and can i fix it, or replace it myself.
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Georgio7564044 Error code E: 61: 10 possible cause for that is an Issue of the zoom driving part. This usually requires a new lens since parts for the internal workings are most often not available. You can always try what is shown here.
Was dit antwoord nuttig?
Score 3
I found the solution from trial and error while I was attempting to fix my camera. There’s a tiny circuit board with a chip attached to a ribbon and red and black cables on the right side (from your perspective facing the viewfinder/eyepiece) of the camera when the shell is disassembled. I’m assuming that’s an accelerometer or other sub-processor for BOSS. Remove it and reseat it to reset the chip.
Score 2
1 Opmerking:
The one just above the headphone output and mic input?
door
Voeg je antwoord toe
georgio7564044 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 66
Afgelopen 30 dagen: 225
Altijd: 8,091
