Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Het W123-chassis omvat de 240D, 300D, 300TD, 280E en diverse andere modellen Mercedes-coupés, sedans en stationwagens uit de modeljaren 1977 tot 1985.
Front Windshield Replacement Help
I’m looking at possibly replacing my 1984 W123 300D front windshield but it seems like no one has any guides as to how to do it? Is there anyone that has written/videoed a guide for how to replace the front windshield?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
So I found this video https://www.youtube.com/watch?v=v4hAT0aS... that shows a windshield replacement on a W116. It seems to be exactly like the W123 so I think I can do it now:)
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Hi, Did you ever do your windshield replacement? I need to do the same on my wagon and also can't find much on the w123. Was the 116 video applicable? I like that he doesn't cut the seal. I have found a car at a local pick-n-pull and I'm now hoping that I could pull the windshield, gasket, trim all together and have extra trim in case I damage mine getting out the windshield. Anyway, thanks for posting the video and I would love to hear any tips you have.
door Deel
Yes I did. That video is pretty much spot on and it went pretty smoothly for me. The trim beside the windshield above the door needs to be removed as well as the inside side plastic pieces and the inside top piece above the rearview mirror.
Good luck!
door Deel
Voeg je antwoord toe
Sanford Helmuth zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 19
Altijd: 1,497
