Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Mute switch and lcd marks?
Hello everyone, i have an iphone 6 and i recently changed the screen. Just around 15 minutes ago, i was cleaning the screen with a cloth and applied a little pressure to remove all the dirt from it, and i noticed some marks on the left side of the screen (only when pressure is applied, not when i touch). The marks are very close to the volume button and mute switch.
My mute switch doesn’t work really well since i broke my phone for the first time (yes this is not my first screen replacement ahahahah) and when i mute the phone it just mutes and unmutes multiple times vibrating.
Here comes the curious thing: when i was applying pressure to my screen with the cloth, the phone vibrated and muted, as i probably triggered the mute switch by pressing on it with the screen.Now the mute switch works perfectly fine again!
I was wondering if there could be any relation with those marks i see, cause in other areas, if i apply pressure there is no mark at all.
Also if it’s not related to the mute switch thing what it could be
I’ll leave a picture to show the area where i see those marks
Thank you so much for reading and sorry for my english as it is not my native language :)
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
The marks you are describing are likely caused by just putting pressure on the LCD which messes with the backlight/visual output. As far as the mute switch, it sounds like there might be a loose connection or a slight tear in the cable and by putting pressure in that area you just managed to make it make contact again. If you look closely to the mute switch cable is there any damage? Even a small scratch or tear can sometimes be enough to stop a component from working.
Hope this helps!
Was dit antwoord nuttig?
Voeg je antwoord toe
Francesc zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 42
