Ga door naar hoofdinhoud
The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
526 Vragen Bekijk alle
Screen flashes on for a second then off after repair
I recently got 2 galaxy s4’s both working fine but one had a damaged screen the other one didn’t as the one with the good screen any way I decided to swap the motherboard from one phone to the other and with a bit of experience with repairing phones I’m pretty sure I did not break anything but when I tried turning the both on after the swap they both just flash on and then straight off again I swapped them back and they worked fine also they are both different model numbers any idea if I swap over every component rather than just the motherboard if that might work
Is dit een goede vraag?
2 opmerkingen
Tao Rain "they are both different model numbers" give us those numbers
door
Yeah one gt9506 and other one is gt9507
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hello,
I had a similar issue with either Samsung S5 or newer. Bought a new screen and it wouldn’t work. Turns out the screens can’t be just swapped between different model numbers. Screen xxxx won’t work on a yyyy motherboard.
Was dit antwoord nuttig?
1 Opmerking:
Yeah makes sense
door
Voeg je antwoord toe
Tao Rain zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 5
Altijd: 42
