Ga door naar hoofdinhoud
Draadloze sporthoofdtelefoon, opvolger van de Backbeat Fit
Headphones not charging - possible error code?
When connected to power, the device flashes red light 15 times and then doesn’t charge. If i depress the power button once during the flash sequence, the red light goes steady and the device charges normally.
Is the 15 flashes an error code? It’s not mentioned anywhere by Plantronics.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Does it always consistently flash 15 times? If not, sounds to me like you have a borked USB cable.
I've also had an issue in the past where the light went solid red and didn't charge. I figured out that the cable between the ears was damaged and had to order a new headset
Was dit antwoord nuttig?
1 Opmerking:
how did you figure that out?
door
Voeg je antwoord toe
Henry Collingridge zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 19
Altijd: 587
