Ga door naar hoofdinhoud
An Acer Aspire 5100 Laptop with a 15.4" inch display.
Have a Bios Error on a 5100 Acer
Laptop will go into Bios but before I go into CMOS program I get an error saying conflicting IO on PCI slot 3. Problem is I'm not finding any settings to modify operating PCI slots. As well this computer was said to have a virus so it will not allow me to look at the OS installed.
Specs:
Acer Aspire BL51
Turion x2 MK-36 2.0 Ghz
1GB Pc4200 200 pin Sodimm
Wireless Adapter: Atheros AR5BMB
160 GB HDD
OS: Windows Vista Home Premium
Any ideas as to what may be wrong been searching and have found no manuals to tear this thing apart and check for loose connections etc.
Is dit een goede vraag?
Score 2
2 opmerkingen
How are the system resources set in the BIOS? Is it set to auto or user defined? Also is plug and play OS set to yes in the BIOS? I believe that the Acer uses the PCI slot 3 for the SD card reader. If your model is equipment with that, try to change your system settings accordingly. Also, do you get the hit F1 to continue or anything like that after you receive your interrupt error message?
door
It asks me to hit F1 to continue and this model does have a SD Card reader. Error Screen Reads:
System BIOS Version: V2.70
Bus:06, Device:02, Function,00
ERROR
Resource Conflict - PCI in slot 03
Bus:06, Device:04, Function:00
ERROR
Bus:06, Device:04, Function:01
ERROR
Bus:06, Device:04, Function:02
ERROR
Bus:06, Device:04, Function:03
ERROR
Press <F1> to resume, <F2> to Setup
That is all I'm getting I may have to see if I can disable or remove the SD Card reader its unnecessary for me to have anyways.
door
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
Still need more info regarding your error, but here is the service manual that will show you how disassemble your Acer. Good Luck
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
Also your comment link is locked to private if you could please set it to public. So I may download or add me to a list of non-blackouts.
door
Sorry had a long shift yesterday :-) try again should be working for you now.
door
Reading the update, it is a hardware error of whatever is using your PCI slot 3 You may have to disable all your non-essential devices in the BIOS and then enable them one at a time to see which one it is. Start with your SD reader. Good Luck
door
+ For the service manual. The problem is more than likely the southbridge with that era of AMD architecture.
door
hallo bij dit probleem werk maar een ding
maak een dualboot met linux ubuntu
deze kijk niet naar bios error maar start altijd op
dan ga je naar opnieuw opstarten en start windows
ook dit gaat dan goed omdat de error weg is
start windows gewoon door probeer het maar voor mij
werkt het succes
iemand met andere ideeen ik hoor ze graag
gr ton
I have the same problem with my Windows Vista, Acer Aspire 5100 Laptop PC. In addition to the error messages my battery was not charging up. I corrected this problem on my computer by uninstalling "Symantec" Products. The PC works great now.
ATi soutbridge defective
Voeg je antwoord toe
Mike Maurer zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 11,165
