Ga door naar hoofdinhoud
Model number NV370. Stands 27 inches tall and features Shark’s never loses suction technology and swivel steering.
20 Vragen Bekijk alle
Roller brush doesn’t turn - Shark Lift-Away brand
I have a Shark Lift-Away, the brush has stopped turning. I have cleaned it, etc.
Is dit een goede vraag?
Score 1
2 opmerkingen:
My roller also stopped working. It would be nice if you could remove brush to see if there is hair wrapped around where the brush connects.
door
@yazminkuba18603 You can remove the brush, but it's not just a matter of snapping open a couple of latches on these machines; there are like 10 screws that have to be taken out but it is doable.
Shark Navigator Roller Brush Replacement
door
Voeg een opmerking toe
4 Antwoorden
If your Shark Navigator Lift-Away Pro vacuum’s floor roller no longer spins, see the Shark Navigator Lift-Away Pro Floor Roller is Not Spinning problem page for possible causes and solutions.
Was dit antwoord nuttig?
2 opmerkingen:
That instruction is basically clean it, it doesn't have an answer.
door
Mine just doesn't work no .atter what I do
door
have check all obvious problems but brush roll wont turn
2 opmerkingen:
I'm having the same issue. Is there a reset button for the beater bar(brush roller)?
door
Mine won't even turn manually.
door
Brand new right out of the box will not pull or push spin brush does not work.... WTF is the problem with this vacuum
1 Opmerking:
Take it back, why worry?
door
It is either:
A stuck brush because of debris
A bad or broken belt
A bad switch or connector
A bad brush motor.
Voeg je antwoord toe
Barbara Glosson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 92
Altijd: 5,546
