Lvds jumper for pin 31
Hello,
is there a possible jumper for the pin 31?
I can't find a board view. Maybe someone have board view.
Any help would be greatly appreciated.
Thanks
Is dit een goede vraag?
Hello,
Thanks
@martl667 pin 32 is ground so it can go anywhere where there is ground. Pin 31 can connect to C9010. If needed pins 30/29/28 can connect to pin 27 or C9001
Was dit antwoord nuttig?
Thanks a lot!
Can I use a normal taped jumper wire cable?
You need to solder it. If you can use some thin strands from something like an old lvds cable etc. Solder your new connector in place and then solder the jumper. If needed pins 30/29/28 could easily be done with a solder bridge (solder connected to each other) to pin 27
you are looking for a new I-PEX 20389-Y30E-01 connector
something like this would work
You’ll need a new connector to fix this correctly. I think you’re good here.
You mean a new lvds connector?
What I have to check with the meter?
If the check good, I can connect from this point to the new lvds. Connector? Right?
Thanks for your help.
Meter equals multimeter?
Using a DVM to check continuity between the two points. The pad may still be there! Even ifs not you'll ned to put a jumper from these two points.
You maybe reaching beyond your skill set here. See if you can find someone local with a good rework station and the needed soldering skills. You'll still need find the connector.
Where are you country and nearest city?
Germany, Nuernberg
Sorry, I don't know of anyone near you.
In any case here's the needed connector I-Pex And here's the source for the connector New I-PEX LCD LED LVDS Cable Connector For iMac 27" A1312 2009 2010
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 21
Altijd: 424
2 opmerkingen
@martl667 what is the 820-XXXX for your logic board?
door oldturkey03
It is the number 820-2733-A
door Martin
