Ga door naar hoofdinhoud
Vizio 42" LED TV released in September 2012.
45 Vragen Bekijk alle
Vizio 75” LED TV Screen Issue
Hello,
I’m assuming that my toddler threw something and hit my 75” Vizio LED TV, but I wasn’t in the room at the time. The screen looks like this:
Is this something that can be repaired easily, or should I just be thinking about replacing it? It’s only 10 months old and still under warranty, but that obviously won’t cover the damage if it was my kiddo.
Thanks in advance!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@scottm219 sorry to be the bearer of bad news. What you have here is a broken panel; no repair possible. A panel that size will most likely cost you more than a new TV (if it is even available). Of course, you can always try and find the same model TV with the same panel but has other issues and harvest the panel from that.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Scott zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 23
Altijd: 460
