Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Can the logic board problems have an affect on activationg the ohone
I have had screen, charging portbatery and home button replaced. Apple support have saidtbey think the phone was not original when I bought it. I did buy online. Apple support have said they think it is motherboard/ logic board problem. Theythink costswil be morethan replacing
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Yes, a common cause is one or more lose solder balls that cause a break in a connection between the baseband chip and the logic board.
What happens as a result is missing IMEI / Modem Firmware (Also when dialing *#06#).
It will cost more than buying a second hand iPhone 6 which makes it economically viable for repair as it requires a micro-soldering technician to do the repair. I would guess at least $80-120 USD.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Wes zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 45
