Ga door naar hoofdinhoud
D1760-2 DECT 6.0 Cordless Home phone with caller ID.
190 Vragen Bekijk alle
I have a uniden 8155+1 and I have done something. When the phone rings
Hi uniden 8155+1 . It does not record messages. I think I have touched the wrong button and being a old person the manual is not making sense. Help please.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi,
If you mean that you just want the answer machine to answer your calls simply press the On/Off button on the answer machine base station or use the handset procedure as outlined below.
The default number of rings before answer is either 2 or 4 rings depending on whether there are any new messages or not, so it won’t give you much time to pick up before it answers. It can be altered to make the phone ring longer before the answer machine answers the call
Use the image below as a guide to which buttons to use in the handset or answer machine.
(click on image to enlarge for better viewing)
To turn the answer machine on or off using the handset.
Pick up the handset and press the Menu/Select button - red box - then use the Up/Down buttons - green arrows - to scroll to Ans.Setup in the display,
Press the Menu/select button then use the up/Down buttons - green arrows - to scroll to Ans On/Off.
Press Menu/Select then use the Up/Down buttons - green arrows - to scroll to On or Off.
Press and hold End/clear - blue box - then release
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
desleymiller1 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 55
