Ga door naar hoofdinhoud
Repair guides and support for the 27" Dell UltraSharp U2711 external display released in February 2010.
How to use iMac monitor stand on VESA VGA monitor
I bought a Digitech Computer Articulating Desk Mount with bracket (model CW-2870) because its cheap. But I want to use it to mount a VGA monitor that is VESA-compliant ! How do you do that?
Update (01/13/2020)
This is the Digitech Computers’ CW-2870 from JayCar
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
It looks like I need to improvise. Oh well, here goes:
  1. First, source a stainless steel strip to ‘construct’ an iMac-like mount
** This will then be mounted on the VGA monitor’s VESA-compliant mount
  1. procure some nut/bolts
  1. drill holes onto the stainless stell strip and attached it to iMac mount of the DigiTech articulating arm with the bolts.
  1. Secure these on to the VESA mount of the monitor
  1. mount the assembled iMac attached to the VESA mount of the monitor onto the monitor
  1. mount the monitor to the articulating arm. Secure with provided allen screw
All done !
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
Hi @junmac ,
Pretty nifty. ;-)
How about you create a guide for others down the track who may not find this post
Durf te repareren: hoe maak je een handleiding?
Cheers.
door
@jayeff
Hope you (and others) find this guide useful
How to mount a VESA monitor on an iMAC monitor arm/stand
Jun
door
Hi @junmac ,
Thank you
door
Voeg je antwoord toe
Jun Mac AUS zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 238
