Ga door naar hoofdinhoud
The fourth-generation Surface Pro tablet, released October 26th, 2015.
208 Vragen Bekijk alle
How can I replace top glass of layer only (LCD and digitizer are fine)
I cracked the topmost glass layer of my Surface Pro 4’s screen. The LCD and digitizer are undamaged and working perfectly. How can I just replace that top glass layer? I found $15 screen protectors made of glass, which I can use to replace the cracked layer. But I'm not sure how to peel the cracked layer off.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
If you are fixing one glass only it is not worth. You need a hot plate and metal wire to remove the front glass, and optical clear adhesive to put a new glass on it.
The "Glass" needs to have the digitizer (touch screen) atached it, a tempered glass or screen protector wont work.
You need tools, screens for practice and hours of work.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Sam D zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 16
Altijd: 601
