Ga door naar hoofdinhoud
Guides for the LTE version of the iPad Mini 4—model A1550. Announced on September 9, 2015, the iPad Mini 4 is the successor to the iPad Mini 3.
35 Vragen Bekijk alle
iPad mini 4 home button replacemnt
I’m repairing an iPad Mini 4 LTE that had a demolished screen - to the point where the wake/lock sensor and home button were almost non-existent.
I’ve installed the replacement screen and home button and was able to get into the settings and turn off the wake/lock feature to get around the need for the sensor. The home button works (no touch id of course), but the bracket isn’t quite stable enough - I used the double sided red adhesive that is normally used on the frame.
What is a standard adhesive to use with the home button brackets (short of using super glue)?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I usually use a good quality tape, either the 3M or Teva tape and then apply a bead of two-part epoxy around the bracket to give it a more solid feel. This is what’s done now right from the factory.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Bill Shannon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 5
Altijd: 93
