Ga door naar hoofdinhoud
Repair guides and support for 17" laptops in the Pavilion Notebook 17 series. These laptops have model numbers 17-g000 – 17-g099.
16 Vragen Bekijk alle
Laptop doesn’t boot makes clicking sound and then repeats
Laptop makes a click or spark sound around the CMOS battery area
17 inch HP Pavilion with i5 4th gen processor
Recently replaced my HDD to an SSD and when I went to test out the SSD I accidentally picked up the laptop to turn it around and forgot about the rechargeable battery which immediately turned off the computer.
I tried rebooting the computer again and it just turns on all lights with fan running and then few seconds later turns off and hearing a click sound that happens when you hard power it off (holding down the power button) and then repeats
What I tried already was resetting the power multiple times and also connecting with only AC adapter to no avail.
Is dit een goede vraag?
4 opmerkingen
James Chen exactly what happened when you "forgot about the rechargeable battery" and turned your laptop over?
door
@oldturkey03 what I mean by that was when I picked up the laptop to turn it around the rechargeable battery came out of its battery contact pins and the computer completely turned off
door
Yes, that is what I thought. Have you checked the connectors/cables and traces to make sure that nothing came loose or got pulled off?
door
Yes I have took each and every cable out and re connected them.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
well this happened to my old computer and was told that i fried the board while trying to replace my hdd
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
James Chen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 559
