Ga door naar hoofdinhoud
Handleidingen voor fornuizen en ovens op gas of elektriciteit.
179 Vragen Bekijk alle
20 PIN Ribbon Connector
I have a Jennair Range JES9860AAS. I am replacing the Electronic Control and have a ribbon cable to disconnect/connect. Can anyone tell me the type/name of connector and how it connects/disconnects? I have attached a picture of the new card and connector. The connector on the old card broke when trying to disconnect. 15 years of thermal cycling made the connector brittle and gave no tolerance for my clumsiness.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I believe this is called a "Pin Head" Connector. To remove the connector you'll want to grab the head of the connector closest to the actual board and gently wiggle it back and forth from each end until it detaches. Do not pull from the wires themselves as this can cause damage to the connector and/or the board.
Was dit antwoord nuttig?
Voeg je antwoord toe
Kyle Levin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 55
