Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De in juni 2016 uitgebrachte Altec Lansing BoomJacket 2 is een kleine, draagbare bluetooth-luidspreker. Hij is ontworpen om overal te werken zonder dat je je zorgen hoeft te maken over schade door de elementen. Modelnummer IMW579-AB-BB (aquablauw)
My speaker stopped charging.
I've had an apparent short in my circuit forever but always found a way to charge it, by positioning the speaker just right. Now it is not charging at all. Any suggestions?
Is dit een goede vraag?
Score 1
3 opmerkingen:
I am having the same problem, but I have isolated it to the power input board. Part number 30-678 Jack MP1.
door Deel
My micro charge connection is damaged. Can anyone recommend a repair center? I reached out to altec lansing but they want proof of purchase. I don’t have my receipt. Any assistance will be great full. TYIA..
door Deel
My micro input is fine. The center conductor looks like it’s pushed in.
door Deel
Voeg een opmerking toe
1 Antwoord
Filteren op:
My best suggestion would be to replace the charging cable if the problem is cable side. If it's the plug itself unfortunately your going to have to open it up and do some soldering.
Was dit antwoord nuttig?
1 Opmerking:
I am having the same problem, but I have isolated it to the power input board. Part number 30-678 Jack MP1. The USB connector has come apart and the board needs to be replaced. You will have to find an Altec Lansing repair shop to order a replacement board. Since the speakers are water proof you will have to pry the connecter out of the shell in order to remove power board and it will get ugly.
door Deel
Voeg je antwoord toe
dpadget3 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 31
Altijd: 764
