Ga door naar hoofdinhoud
Device and repair guides for the 2016 Samsung Galaxy J5 Prime smartphone, model number SM-G570Y or G570.
74 Vragen Bekijk alle
Why is my phone restarting itself
My phone keeps restarting itself, when I switch it on, the screen reads android is starting , optimizing APP 1 OF 1, then reads starting app, vibrates once switches on for less than 5 seconds then restarts again. It continues to restarts itself until battery runs flat.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @annah44 ,
Things to try without resorting to a factory reset.
Try clearing the phone’s cache partition and check if this resolves the problem.
DO NOT select wipe data/factory reset as this will erase all your data and downloaded apps and reinstall the operating system.
Try starting the phone in safe mode and see if the stops boot looping.
If it does then a downloaded app is the cause of the problem. The trick is to find out which one is the culprit.
You will need to uninstall each downloaded app, one by one and test the phone in normal mode between each uninstall to check if the problem is still there or not. When it is OK then the last downloaded app that was uninstalled was the cause of the problem.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Annah Chiweshe zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 23
Altijd: 566
