HELP:My earbuds come up as two separate Bluetooth devices- How to fix?
How can I Force the two earbuds to sync up and become one Bluetooth device?
They are coming up as two separate Bluetooth devices in settings and I can only connect to one at a time.
Is there a way to force reset them?
Disclaimer: I cannot Reset through the app as that only works with two of them connected. Right now I'm the wearables app there are two separate devices.
Is dit een goede vraag?
i have tried resting my earbuds and disconnecting them but they still show up as different devices. i use a galaxy tab A (8.0 2019) samsung tablet. nothing is working and this is a newer pair because only one earbud connected with my last pair. please help T^T
door Demons' *Pride*
I had the same problem. Optimum T21 earbuds only worked 1 at a time. Your solution fixed the issue. Only thing is that I am no longer getting stereo that I got before. The update may have been a good idea to have 2 seperate devices but the issues were not thought through.
door wiltriker
I have the TCL MOVEAUDIO S150, at first, it showed as one device but somehow I made them into two separate devices now, Idk how to fully reset since it doesn’t have any button to do so. Any help would appreciate it.
door João Delgadinho
This is a phone issue...
What happened with me is...
I used one bud at a time...I noticed my phone audio in setting equalizer to Jazz
Other was to custom
I made bothe default one by one....and that it:)
door Kishan Ruparelia
I found a fix that worked for me!
First make sure both buds are unpaired and put both back in the case. Then pull them back out and make sure both lights are flashing blue, then double tap one of the buds - usually the left one works best - and the other's light should turn off. Refresh the Bluetooth list on your device to make sure there is only one connection showing then hit pair!
Hopefully this isn't too confusing!
door Kayla Sims
14 commentaren meer tonen
