Ga door naar hoofdinhoud
Apple's third-generation smartwatch, with optional cellular connectivity, released September 22, 2017.
197 Vragen Bekijk alle
Apple Watch series 3 no touch after screen replacement
I recently replaced the screen on my Apple Watch series 3 Nike + edition. The screen comes on and the buttons work but there is no reaction from the device when I touch the screen. I have tried force restarting it dozens of times and it has changed nothing. The old broken screen does not work at all so I believe that trying to use the old digitizer will not work. Anyone have any ideas?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Sounds like either the display assembly was defective or the cable connection from the SIP was not fully inserted and latched or was damaged.
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
I have tried reseating the cables a couple of times and that hasn't changed anything, unfortunately, so I am beginning to wonder if there is another component that might be damaged or if the unit is now useless
door
I went back and tried your solution and to my surprise, it worked! I can't believe it was that simple of a solution, thank you!
door
What exactly was the solution? @Blake Russell
door
@chi.areadj - Either the cable was not fulled inserted or the display unit was defective.
door
Blake what was it that you did exactly? I am having the same problem…I can’t get touch to work. The touch cable appears to be seated into the connector…I’m stumped
1 Opmerking:
Hi Jerrod, did you ever resolve the problem with your watch? I have the same issue.
door
For me the solution was update the firmware and after the touchscreen start to work fine.
1 Opmerking:
I purchased one of these sapphire screens for series 3. Screen works but in constant restore loop. Firmware upgrade fails each time also
door
Voeg je antwoord toe
Blake Russell zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 86
Altijd: 4,011
