Ga door naar hoofdinhoud
Other than the Tahoe Limited Edition, the vehicle was redesigned for the 2000 model year on the new GMT800 platform, still shared with the full-sized pickups and SUV's.
46 Vragen Bekijk alle
How to stop the low pressure message!
Hi, I’ve been having a problem with my 2003 Yukon XL where I constantly get a low oil pressure warning. I have checked my oil and it’s been full and clean every time. I have had the sensor replaced recently. I was wondering if anyone knows how to just turn the message off or at least make the annoying beeping stop?
Is dit een goede vraag?
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
Hi @kt545,
Since you have replaced the oil pressure sender unit get the engine’s oil pump tested by a mechanic.
If there is insufficient oil pressure in an engine it could damage the engine
Was dit antwoord nuttig?
Score 2
you would need to disconnect the sensor and program the ecu to ignore both. low oil pressure doesn’t mean dirty and low oil, there’s not enough force pumping it around the car, if the wiring is fine and the sensor there is low pressure, I wouldn’t advise just muting the warning as the engine needs it to lubricate itself and could cause engine failure and an expensive mechanic bill.
Oil pickup o-ring.
Very common
Get a better diagnosis could be a couple things. Ultimately change everything at once unlike me.
Voeg je antwoord toe
Katie Mcdonough zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 48
Altijd: 2,425
