Ga door naar hoofdinhoud
De Samsung NP300E5C-A09US, een pc uit de Samsung Series 3, is een 15-inch laptop met een schermresolutie van 1366x768. Het is een uitstekende keuze voor iedereen die op zoek is naar een lichtgewicht, maar krachtige draagbare computer.
No BIOS or OS
I have a old Samsung NP300E5X-A0ANG (which a model number IFIXIT didn't have)
I had Linux Ubuntu installed on it which for some reason stopped working so i decided to wipe the drive and start fresh but i come to realize it no longer has BIOS at all
So i have no way of getting into a one time boot menu no idea what button(s) i have use to flash an old .bin file i apparently had in Google drive (i have a account were i only put drivers and firmware etc. On it in case i ever need it)
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
3 Antwoorden
Filteren op:
I think you are saying that you can not access the bios…it must have a bios if it was booting but perhaps the access to the bios is corrupted? I would take the unit apart (look for tear down videos of similar models or search for some instructions…I had to do that with my obsolete and uncommon laptop and somehow found enough info). You’ll need to locate the CR2032 or similar bios battery holder on the motherboard and replace the battery.
Was dit antwoord nuttig?
1 Opmerking:
Tried that didn't work and yes what i mean is i cant access a Bios anymore
door
The problem is caused by UEFI boot after installing Debian Linux. The Samsung BIOS is faulty by default and if I know well it is not yet fixed by the manufacturer. I had the same problem. The only solution is BIOS Flash. It can be done if you buy a programmer like CH341A. There is a great tutorial how to make it: ++https://jensd.be/980/linux/bios-or-spi-p...
Hi! I have an NP300E5C, ita version. And yeah, same issue. After some long researches, it came out that installing linux on these laptops, corrupts the NVRAM. For this reason, the bios becomes not accessible anymore, and the os doesn't boot anymore. Other drives won't boot too. Try to enter the boot menu pressing some random F keys. If this doesn't work, unfortunately you can fix only by replacing the bios chip (costs around 15€ on ebay, not really expensive)
Voeg je antwoord toe
Sam Tahir zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 29
Altijd: 1,976
