That’s usually due to layer delamination due to a panel defect, especially if it spreads over time. The problem is you can’t fix this without replacing the entire panel. Unless the panel is fine and it just needs to be cleaned out internally (which is still a risk, but it’s doable if you’re careful), it’s usually unrepairable.
The problem is with most 1st party panel manufacturers, it’s typically cheaper to replace the monitor as a unit due to the cost of the actual panel itself, and this is usually the case with LG and Samsung as they make their own panels. That being said, sometimes Samsung doesn’t use their own and uses a 3rd party one, so they also are sometimes cheap to salvage - it’s usually AUO if this happens. However, unless you can find a cheap panel, it’s usually better to replace the monitor as a unit since it’s almost always a lose-lose proposition cost wise. Acer, AOC and Dell are not panel manufacturers, so you can somethimes get off lucky with those types of monitor brands.
Make sure you reset the panel hours as well if you find one that’s brand new. On Samsung, set the brightness and contrast to 0, exit the adjustment mode (if needed - not always required) and hold down input. For joystick control, navigate to input and hold it down until the service menu comes up. Hold menu on panel hours for 3 seconds and it resets.
You’re one of the unlucky ones :-(. This uses a Samsung LTM panel (LTM185AT01). Since this doesn’t look like one where AUO panels are a backup plan for short internal supply, the panel likely won’t be cheap when you can get something newer with a more current port configuration (or at least a DVI/VGA with a DHI->HDMI adapter included in the box - which Samsung sometimes does with their older designs to cover for the fact many new GPUs and towers no longer use DVI). The service manual can be found here (translation required). It’s also not readily available new, so you may need to get a used one on eBay with minor issues at a discount you can accept, or at least find the AUO equivalent part if multiple panels were used and try your luck.
11 opmerkingen
Hi,
What is the make and model number of the monitor?
Has the monitor gotten wet at all or is it in a very humid environment?
door jayeff
The room is always in dry and a bit hot ,air flow & ventilation a bit bad there. But the heat from CPU computer add up in that room. I think it's not wet at all... Or humid enviromental.
Aha! I just remember , there was once ,
One or two drops cooked oil from my Meals spilled onto the top of monitor and some oil go down to the front part of monitor ,not inside(which we stare everyday). I wiped them up ASAP with Dry tissue+Alcohol
i think a little oil go down inside through the gap of the monitor's thin casing on top side?
door mymobilelegendss
@mymobilelegendss what make and model is your monitor?
door oldturkey03
@oldturkey03 It's some sort of Samsung. I had a hunch based on the design and it's confirmed in the photos (2nd photo). It looks like a 24" 1080p to me.
door Nick
@nick Yup, but some sort of Samsung really doesn't help us out here
door oldturkey03
6 commentaren meer tonen
