Ga door naar hoofdinhoud
Model A1990 / EMC 3359. Released in May 2019 with new 6-core and 8-core processor options.
87 Vragen Bekijk alle
MacBook stuck on black screen
About a month ago my 2019 MacBook Pro was stuck on a blank screen.
It’s like the laptop was still working, but the screen stopped working. There would be a sound when I plugged the charger in, I could hear the fans working, I could even charge my phone. But the screen stayed black.
Eventually I found a fix online. I reset something by holding keys down after pressing the power button and it started working again.
Anyways, this exact same thing has happened (black screen), but I’ve forgotten what I reset to make it work again.
Can anyone suggest what I could try?
It wasn’t the SMC or PRAM/NVRAM. It was another one which I found only after hours of searching.
Any help would be greatly appreciated.
Is dit een goede vraag?
Score 1
1 Opmerking:
Hi Josh. I am facing the same problem, did you find a fix?
door
Voeg een opmerking toe
1 Antwoord
Does an external monitor work?
The only other keyboard command is toggling AirPay on/off via the TouchBar AirPlay button or in the displays menu bar.
Was dit antwoord nuttig?
Voeg je antwoord toe
Josh zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 1,393
