Ga door naar hoofdinhoud
Device and repair information for the Dell XPS 13 laptop models 9343 and 9350, which were both released in 2015.
20 Vragen Bekijk alle
Four flashes. Battery isn’t recognized by laptop.
Just replaced my dying battery with one from ifixit.
The white charging light appears when I attach the ac adapter, then I get four orange flashes.
The internet says this means a bad battery. Did I receive a bad battery or is there something else that could be at play here?
EPILOGUE: I followed the recommendation, started the process. For giggles, I unplugged and repeated the connection and realized it had been user error. Fixit troubleshooting 101.
Is dit een goede vraag?
Score 1
1 Opmerking
Hi,
What happens if you leave it on charge for a while, does it stop flashing?
Have you tried re-installing the old battery to check if the problem is still there, assuming that it didn't do this before?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
EPILOGUE: I followed the recommendation of jayeff and started the process of confirming connectivity with the old battery. For giggles, I unplugged and repeated the connection and realized it had been user error. I just hadn’t pushed the connector in far enough. Shame on me. Fixit troubleshooting 101.
Was dit antwoord nuttig?
1 Opmerking:
I am having the same problem you've described, but with no luck on playing with the connection. The old battery re-connected just fine, but the ifixit battery didn't. After hours of sitting plugged in, the flashing orange light continues, and when I unplug the computer it immediately dies. So the battery isn't connecting. Makes me wonder if i got a bad battery.
door
Het nuttigste antwoord
discosammy enter the "Epilogue" as an answer so we can mark this question as resolved.
Score 1
Voeg je antwoord toe
discosammy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 1,123
