Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
Logic board bent co
This 3GS was run over by a trailer and I disassembled to try and repair but the first thing I noticed was the logic board is warped! I put a working display on it to test it because the digitizer and LCD were crushed and it's not doing anything. Is there anyway to fix a bent board also is this what is causing it not to work?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I think you can be sure that if the logic board is bent it is not possible to fix it.
Was dit antwoord nuttig?
Voeg je antwoord toe
Jared zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 651
