Ga door naar hoofdinhoud
Repair information and guides for the iPhone 8 that was released on September 22, 2017. Model: A1863, A1905
873 Vragen Bekijk alle
Issues after replacing charging port
I just replaced the charging port in iphone 8, the phone is now turning off when I put phone to ear when making a call. Also the lock button is turning off the phone too. Any idea what I need to do?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
The problems you are describing are somewhat generic and could be interpreted as normal functions on the iPhone. We need more details about what specifically the phone is doing that it shouldn’t.
Looking at them as a problem, they shouldn’t be related to the charging port replacement itself. The malfunction may have been caused by improper installation on the other parts when reassembling the device. Recheck your work following this guide to see if anything doesn’t look right.
Was dit antwoord nuttig?
2 opmerkingen:
During a phone call it is completely shutting down that it drops call and the screen just has the apple symbol on it. The lock button turns the phone completely off that I have to hold it to turn it back on. I did everything in the steps shown. But unsure what the new issues might be caused by.
door
Thanks for the info. It sounds like a complicated power draw issue within the logic board itself. Could be from an inbalance somewhere else. Try to disconnect other parts to see if the issue is still there. Try first to disconnect the new charging port and test for the issues. Then try disconnecting other components near the top like the rear camera etc. If you get normal function when something is unplugged, that is your bad component.
door
Voeg je antwoord toe
ashley_marie_89 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 80
