Can I run this under 19v
so I have this and I don’t have a charger for it can I run it off like 15v or 12v if possible if I can what hardware do I have to take off to make it run?
Is dit een goede vraag?
no lest then 18 volt
Was dit antwoord nuttig?
so I cant do it under period? but I can do 18? in order to make it run on 18v do i have to remove anything?
nothing to remove u only need a 18 volt adapter or 19
The voltage regulator inside should handle an undervoltage but I would not go too low as this will cause excess heat.
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 10
Altijd: 66
