Ga door naar hoofdinhoud
Hyundai launched a redesign of the Santa Fe on February 14, 2012, and went on sale in June 2012 as a 2013 model.
20 Vragen Bekijk alle
Car vibrate at 70-90 km
My car vibrates at 70-90 km and once I cross 100 it become completely normal, I thought it might because if tires balancing but I got the balancing done and it still continues, does anyone know what’s the problem thanks
Is dit een goede vraag?
4 opmerkingen:
Does the steering wheel also vibrate?
door
Yes I can feel it, the whole car vibrates
door
Jignesh Patel yours the All Wheel drive model?
door
No fwd 2.4 litre engine
door
Voeg een opmerking toe
2 Antwoorden
You likely have out of balance CV assembly
These are the symptoms of a bad or failing CV axle shaft assembly
Was dit antwoord nuttig?
1 Opmerking:
I will have to check with my mechanic.
door
Jignesh Patel  rotate your tires or change your tires. Have a good mechanic check your front end including the ball joints and tie rod ends.
1 Opmerking:
I rotated the tires but still the same problem, in fact, I changed my all-season tires with Winter tires and still have the same problem.
door
Voeg je antwoord toe
Jignesh Patel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 275
