Ga door naar hoofdinhoud
Repair guides and troubleshooting for the HP Compaq DC7500, a business class desktop computer introduced in 2007.
21 Vragen Bekijk alle
My pc is not starting just making beeps 9 times with red light blinks
my pc is not starting just constantly beeping for nine times with red light flash again & again. I can’t recognize what problem it has, I watched some videos to fix it on youtube but I find out that my pc is beeping for 9 times all of the videos that I watched on youtube have the solution for 5 beeps none have 9 beep problem solution.
Is dit een goede vraag?
Score 5
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
Here’s an image taken from page C-11 of the service reference guide for your desktop, which shows what a 9 beep error code can mean.
It could be a faulty PSU so check the various voltages being supplied by the PSU to the motherboard to make sure that they are all OK.
If they are OK then it may be a CPU fault or a motherboard fault.
(click on image to enlarge for better viewing).
Hopefully this is of some help
Was dit antwoord nuttig?
Score 6
1 Opmerking:
You need to replace supply other wise motherboard need to replace
door
Voeg je antwoord toe
Moazzam Ali zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 47
Afgelopen 30 dagen: 202
Altijd: 9,590
