Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Vragen Bekijk alle
iPhone stuck in recovery mode
My phone started randomly shutting off and then on again. Every time it would turn on, it would be on for a minute or even less, turn off again and then start turning on again on its own. I tried fixing it by getting it into recovery mode - that didn’t work even though I tried doing it multiple times. At some point, my phone just got stuck in recovery mode, and now it won’t turn on at all.
I also tried connecting it to iTunes and updating iOS while in recovery mode, but every time I would get some sort of error, usually error 75.
I have no idea what else to do, and I would like to avoid putting it into DFU mode. Any help would be greatly appreciated. Thanks!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
If a new battery and charge port doesn’t improve the situation, then your next ‘most likely’ fault would be damage to the tristar usb recognition chip which can cause these symptoms. Changing tristar is not a DIY job, but can readily be done by any competent microsolderer. If not tristar, then it can be failure or corruption of the flash memory chip.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
anastasija zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 2,222
