Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
J2019 Diode Mode Values OK but Black Screen
HI
Iphone 6 PCB 820-3846A
J2019 Connector on PP5V7 LCD AVDDN CONN was 0L.
Changed U1501 and U1503 ow Diode value Reading is OK but still screen Black
Changed FPC Too just in case , same thing
Can any one help me in this case ?
Thanks in Advance
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Do you mean PN5V7_SAGE_AVDDN or PP5V7_LCM_AVDDH; the rail you mention does not exist. It’s quite common for the PN5V7_SAGE_AVDDN to read OL so if that’s the case, I wouldn’t worry about it.
Did you check all of the connector pins or just some of them? When dealing with a dark/black screen, you need to insure everything reads okay and when possible, measure the actual voltages as well. You can get the QIANLI iBridge Test Cable to help you troubleshoot these kinds of issues.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Formingus zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 127
