Ga door naar hoofdinhoud
The LG Stylo 4 is a stylus-equipped midrange slate-format Android smartphone released by LG in 2018. Identifiable by model numbers L713DL and Q710(AL, CS, MS, TS, ULM, ULS, and US).
20 Vragen Bekijk alle
How can I fix this connected disconnected charging issue?
When I plug it in it charges for a bit and the soon starts rapidly charging and stopping. Nothing is touching it and I've tried fidgeting with the charger by the charging port but it doesn't change anything. I've also tried with other cables and they don't help. Is there any way to fix this?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Paige Jandreau  since you already tried all external solutions, you may have to replace the charging port. Your phone uses a flex connection for that. So, time to take it apart (PITA) Use something like this video to get into your phone. This is the part you will have to replace.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thank you so much!
door
Voeg je antwoord toe
Paige Jandreau zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 654
