Leak from bottom front of Bosch washing machine
When the jets in the soap dispenser spray into the soap dispenser at the start of a cycle, the water which is going down the pipe from the bottom left of the dispenser hole is leaking.
I can clearly see that the pipe which sits underneath the dispenser tray which I think is supposed to take the majority of the excess water away, is not sitting flush with the hole it sits under. I can move the the pipe so it sits underneath quite easily, but each wash the vibrations seem to shift the pipe so that there is a gap for water to escape again.
My questions are:
- is there some way that the top of this pipe is supposed to seal or clip around the bottom of the tray to prevent it moving sideways out of place?
- if this keeps happening but I can’t see any issue hole or rip in the pipe, will replacing the pipe help with the seal?
Any help would be hugely appreciated.
My issue is not with the dispenser drawer or blockages or high water pressure as most sites seem to call the most common problem
Thanks
Is dit een goede vraag?
2 opmerkingen
Hi @simieski ,
What is the model number of your washer?
door jayeff
@jayeff it’s a Bosch Exxcel WAQ283S0GB
door Simieski
