Ga door naar hoofdinhoud
No service cant activate
My phone has no service does searching for signal tried other sims still an issue did a factory reset I wasnt signed into my icloud account when I reset it but now phone is bricked will not activate what do I do?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Not much you can do, since all points to a hardware issue that needs a microsoldering repair where skills and tools are needed. If the iPhone was dropped in the past or the audio IC was previously repaired that would explain the why, although it would not change the picture.
Was dit antwoord nuttig?
Score 4
2 opmerkingen:
Yeah I have all the tools and equipment but no skill
door
@consistent That takes lots of time, dedication and try and error, but it's also fun and might be rewarding in the end :)
door
Im having the same problem, I even changed the busted antenna chip at the local store. Still bricked. Do you think theres a brute force way to activate it? A third party program maybe?
Voeg je antwoord toe
Mark D Schlossman zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 88
