Ga door naar hoofdinhoud
Product Dimensions: 6.3 x 3.1 x 6.3 inches Item Weight: 7.8 ounces Item model number: 04091378 Released: February 2016
2 Vragen Bekijk alle
What battery type is in Marshall Major 2 Bluetooth?
I’ve been using Marshall Major 2 Bluetooth for 22 months. Recently the headphone stopped charging — instead of blinking red light when plugged in, I see a very dim solid white light. I searched in forums and apparently several other people had the same problem. Somebody recommended (aside from the 12-month warranty) replacing the battery.
Is it okay to replace the non-working original battery with an average Lithium Polymer battery? It says somewhere that the original batteries are 680 mAh.
Update (11/11/2019)
Hi @oldturkey03, so I have bought a LiPo battery, but turns out it’s without NTC. The original battery inside the headphone has NTC.
Can I just omit the NTC connection?
The connection inside the headphone:
The battery I bought:
Is dit een goede vraag?
Score 1
10 opmerkingen
@gizatm personally I would not. NTC is what can keep your battery from overcharging etc. I am not sure if your charger etc. would recognize when to stop charging etc. It might work temporarily but I'd be a little leery and would try to find one that gives me that extra little bit of protection.
door
@Coding Tintin  I have the same problem.Is it fixed with the battery you bought ?
please answer.
door
@Arman Mkrtchian, unfortunately, not yet. If you look at the image, the battery I bought has only two cables. The Marshall headphones require the third one for NTC. So now I need a battery with three cables. Right now it's not fixed.
If you do fix it, please, write here. Currently I can't find the battery on Alibaba. Might need to look at Amazon.
door
@Coding Tintin ok, I will write.
door
I have found something like this, and it does look like it should be working like a charm!
I have just ordered it, so it will take a while, to give my review.
https://www.aliexpress.com/item/32996928...
door
5 commentaren meer tonen
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@gizatm yes it is for as long as the voltage is the same and the physical size will fit. A lower mAh or greater mAh just means that you may have to recharge the battery faster/lesser.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Thank you, I will try fixing it myself with this method.
door
Voeg je antwoord toe
Coding Tintin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 142
Altijd: 9,112
