Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
Charging problem with battery
Hey.
So i have a strange case going which i have been working on for a few weeks now.
A customer came in with he’s 6S because the phone was dead and not charging at all. I testet this with a USB voltage measure unit and confirmed that the phone does not take any charge what so ever.
Naturally i suspected the battery and replaced it. The phone was working fine and was charging like normal. Then the customer comes back with the same problem. I tried charging it while using the USB voltage measure unit and it said 0.00V. So i took the battery out and measured it to 3.26V. The phone needs 3.8V to start but not to charge. I placed the battery on a charging plate (activation plate). I had it there until the battery reached 4.05V and then put it back in the phone. Again phone turned on and received charging fine. I charged the phone to 100% and left it on without charger over night.
I came back the day after and the phone was off and again didn’t receive any charging. So i checked the battery voltage again and measured it to 3.03V. I put the battery back on charging plate again and charged it to 4.05V. I put the battery back into the phone, the phone turns on and receives charging just fine.
I have tried this with 4 different batteries from different suppliers including the original one. The result is the same every time. I now suspect the Power Management IC.
Anyone out there experience this?
Anyone knows how to fix it or what to do?
Is there something else i can test?
Thanks in advance for all answers!
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
It has nothing to do with the power management IC. Is it drawing any current before prompt to boot? If so how much? You will need a power supply and or multimeter for us to help you.
If you haven’t got a DCPS then tell us what the diode measurements are on VCC_MAIN (red probe on ground) We can go from there.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Thank you for you answer.
I’ve checked using the DCPS and here is what i,m getting:
Before boot 0.4A.
While booting 0.8A
After boot with screen on, between 0.65A to 1.65A.
After boot with screen off, between 0.35A to 0.4A.
door
You have a partial short on VCC_MAIN or BATT_VCC Unlike a full short these can be tricky to find as they might not put out enough heat to track down.
Check your BATT_VCC line first if that is alright I would inject 4V into VCC_MAIN with some freeze spray and see if you can find the short. Or use a thermal cam.
If the phone has not been water damaged I have a hunch it might be Tigris or the charging mosfet Q2300. I would remove Q2300 and test VCC_MAIN with a multimeter and see if the short has gone. Compare the readings with a known good board. Remember when short finding unless you inject the voltage into VCC_MAIN the mosfet will heat up and you might get trolled by it. Do a really good visual exam first; something might pock its head out.
door
This actually doesn’t sound like a battery issue. The device has a short on the mother board of some kind. This short is causing the battery to drain and discharge past a operating voltage. Once it gets too low the battery won’t charge. Gonna require motherboard repair.
Voeg je antwoord toe
Total Repairs AS zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 377
