Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2660 Vragen Bekijk alle
6s stuck on apple logo, tried all the normal solutions.
Hello.
So I went to fix my friends iPhone 6s for what I assumed was just a simple battery problem. His phone randomly stopped working and got stuck on the apple logo, unable to go to the homescreen.
Tried a new battery, tried other batteries, same issue. I then took his screen/the new battery and tried on a different iPhone 6s and they both worked perfectly fine.
I tried a new screen on his phone, same issue. Tried unplugging all the cables (charging port, home button cable, front facing camera, back camera). Pretty much tried everything I know on how to fix this type of solution and unfortunately had no luck.
As a last resort I wanted to come here and see if anyone has any other suggestions for me to attempt. It stays on the apple logo forever before it has a quick flash, then back on the logo. Then eventually the screen just goes black. Appreciate any suggestions and help
Is dit een goede vraag?
12 opmerkingen:
Try updating it through iTunes and see what happens.
door
Okay, will def give that a try.
Thanks
door
Could be that he doesn’t have enough space on the phone to start. Had the same issue and I had to completely restore the phone
door
watch this video will help you fix your stuck on logo iphone https://youtu.be/0XGMFmHLFCw
door
Watched the video, I know about 3utools. Doesn't the software cost money?
door
7 commentaren meer tonen
Voeg een opmerking toe
1 Antwoord
Software crash thats why is not loading, try to put it in DFU Mode , if you get it to DFU mode there’s the issue. you can try to update it but it might fail , if you flash it from 3Utools still gonna restore the device
Was dit antwoord nuttig?
1 Opmerking:
It's in DFU mode, tried to flash it with 3utools while retaining users data and failed at 33%
Having trouble getting it out of DFU mode now.
door
Voeg je antwoord toe
Ian Romprey zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 94
