Ga door naar hoofdinhoud
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
774 Vragen Bekijk alle
Display is not working (no apple logo light)
Short story:
I took my MacBook Pro to an Apple authorized service center to replace my display for stain-gate program. They told me my system had liquid spills but they can replace the display it at my own risk, I then accepted. Now they give me my laptop with new screen but the screen is black.
  • Its’ working with external monitor through HDMI.
  • Apple logo doesn’t light up
  • I’ve already tried reboot methods holding keys but didn’t worked for me.
Please help me telling me which part could be the problem to find the right technical service in my city.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Take a lit flashlight and shine it through the back Apple Logo. Are you able to see your desktop icons? If you do then your logic board needs service.
Was dit antwoord nuttig?
2 opmerkingen:
Hi Dan. I´ve already tried with flashlight through the logo but there´s no image, all black.
door
@pazbaraybar - At this point you'll need to inspect the display connector on the logic board and the cable for corrosion as the video signal is not getting to the display. Take some pics and post them here for us to see Voeg afbeeldingen toe aan een bestaande vraag
door
hi guys, I have the same problem. Do you think do I need change conector?
1 Opmerking:
I see some corrosion on the pins, someone with good micro-soldering skills should be able to clean up these solder joints. Hopefully thats all thats needed.
door
Voeg je antwoord toe
Betto Paz zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 38
Altijd: 1,336
