Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Phone restarting for some days than died
Hi everyone, at first I want to apologize for my bad english and to thank you for your time.
Last year I brought my uncle’s dead iphone (won’t turn on) to the apple store and after replacing the battery they gave it to me saying that the motherboard was dead and that i can keep the new battery. So far so good I bought a new motherboard with touch id, a new Charging chip (just to be sure) and i swapped them. The phone worked fine for 1 year and a week ago it started to restart in loop while i was using it, The problem was so bad that I had to reset the phone with itunes. Nothing changed and for the last week the problem persisted. Until yesterday: i was using safari and suddently the phone shut down without even restart. I tried to charge it, i tried to restart in every way but it’s dead.
Now I’m asking you: do i have to buy another motherboard? Or can I do something cheaper like test and swap some capacitors? In that case i have a tester but i don’t know which capacitors I have to test and which result indicates a bad one. And last question: could it be that I installed the motherboard in a wrong way? It seems strange to me because if I failed with the installation the phone couln’t work for 1 year..
thank you again for your time, I really appreciate it!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
You can try to put a new battery in it and look if that will help, it is the cheapest way.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thanks than, I'll try. If it's not the battery what do I do?
door
I Tried but nothing, after it sat for a week it started but after a few seconds it restarted again and then turn off. I noticed that besides it was fully charged last week when i restarted it i had to charge it again because the battery was completely drained
door
Voeg je antwoord toe
Alessandro Be zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 35
