Ga door naar hoofdinhoud
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
773 Vragen Bekijk alle
Doesn‘t turn on.
When I press the power button the fans spin, but no chime, nothing boots. I tried resetting pram/nvram and smc, both didn‘t work. Happend after a regular shutdown. No liquid damage, no burn marks on the board. Running Catalina. What is going wrong?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Disconnect the battery from the logic board. Disconnect the MagSafe adapter. Press and hold the power button for 10 seconds. Plug the battery back in, then the MagSafe. You should get a spontaneous reboot.
MacBook Pro 15" Retina-scherm mid 2015 Vervanging van de batterij
Was dit antwoord nuttig?
Score 3
6 opmerkingen:
Hmm, so now the screen lights up and tells me it has no battery. I‘ve had it connected to the charger for roughly 15 minutes, still no change.
door
@Tea God - Let it charge up for the night
door
Thanks, worked out. Saved my day :)
door
same problem... do you mean unplug the battery connector or the remove the entire battery component?
door
@tjbennett - first disconnect the battery follow the fist steps in the guide pasted above. Press the power button for a good 15 secs, the plug in the MagSafe charger not the battery! The system should spontaneously start up, let if fully boot up and do a proper shutdown, then reconned the battery and give it a try.
If the system fails to boot up or if after reconnecting the battery it fails to boot you have deeper issues which need to be diagnosed.
door
1 commentaar meer tonen
Voeg je antwoord toe
Tea God zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 67
