Ga door naar hoofdinhoud
Released April 2018. Identified by model number EML-L29.
22 Vragen Bekijk alle
[P20 Lite] Is the problem with my screen or motherboard?
I was given a phone what had fell down from a high place, if you turn the phone on / or put the charging cable in the phone, the phone vibrates, a flashing red-light occurs at the top of the phone and screen gets some red&blue&green lines running through it.
I’d like to know if the problem is with the screen or the motherboard, is it worth fixing?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @roal ,
it’s a LCD&Digitizer issue. Follow this video to see, how to repair your issue.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thanks, just put my order in for new LCD & frame.
Cheers mate, hopefully I'll be able to make the repair :)
door
You are welcome, you will fix it! :) Good luck
door
Voeg je antwoord toe
Raul zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 25
Altijd: 1,307
