Ga door naar hoofdinhoud
Uitgekomen op 4 november 2017. Model A1865, A1901. Verkrijgbaar als GSM of CDMA / 64 of 256 GB / Zilver of Space Gray. (Uitgesproken als "iPhone 10".)
iPhone X boot loop issue
I am a technician with the skills and access to microsoldering equipment. I am trying to avoid separating the two board layers if possible because it is a pain to get back together and may not be necessary. The phone is doing a 3 second boot loop. I have tried to turn it on with only essential components plugged and I have frankensteined new hardware in order to rule out hardware issues. It is recognized by iTunes. I attempted every reset possible, and none of them work. When attempting to restore the iPhone through iTunes, the restore stops right after extracting software (likely because of whatever is causing the boot loop). On the board level, are there any pads I can test in order to confirm that I need to split the boards? Does anyone have a clue what might be causing the issue? On my USB detector, the output reads a stagnant 0.47A @ 5.09V
Is dit een goede vraag?
Score 1
1 Opmerking
Mine does exactly the same thing on trying to restore
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Check around nand for shorts. But the problem could be the solder joints.
Was dit antwoord nuttig?
Score 1
Try a genuine replacement charge port assembly. They can cause reboots when they go faulty.
Score 1
Voeg je antwoord toe
Batteries Bulbs zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 24
Altijd: 247
