Ga door naar hoofdinhoud
De a7R II (modelnr. ILCE‑7RM2) is Sony's revisie uit 2015 van hun spiegelloze systeemcamera met full-frame sensor en verwisselbare lenzen.
Menu scrolling through itself like crazy
My Sony A7S Mark 2 is moving the menu by it self please how do I fix this?
Is dit een goede vraag?
5 opmerkingen
hi, i have the same problem with my Sony A7ii. Menus switching on its own and sometimes goes back to normal then switching and scrolls again.
Did you already FIX yours??
Thank you :)
door
Same problem. Any help?
door
Me too. Anyone sort it?
door
Very late reply. Got mine fixed at the nearest camera repair shop for USD65.
They say this is a common problem with Sony A7II after sometime...
door
Hi. Did they say what the problem was that fixed the camera? 65$ is pretty affordable. Thanks
door
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
Hey, Shakily_17
The issue could be that you need to replace the buttons, but it's likely that a ribbon cable isn't fully connected or it is damaged. This issue can be found in other devices such as the Sony Dualshock 3 and the Asus Zenbook.
Was dit antwoord nuttig?
Score 2
Sounds like a "Stuck Button" Problem. Common with most devices that you use the buttons, when they aren't cleaned they can stick. Even if the "External Buttons", or the button layovers, are cleaned, the internal buttons may be dirty. Try cleaning the buttons with Isopropyl Alcohol, and a soft electronics towel. If that doesn't work, check the cables and clean the internal buttons and cables if necessary.
Score 1
Voeg je antwoord toe
shaikly_17 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 49
Altijd: 1,736
