Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatiehandleidingen en ondersteuning voor 17" laptops uit de Pavilion Notebook 17-serie. Deze laptops hebben modelnummers 17-g000 – 17-g099.
System Fan (90B) error
Hi
The laptop gives this error at the BIOS boot up stage.
The fan sounds like it spins up and down a few times.
The system then shuts down.
I opened up the laptop and the fan spun freely with my fingers. I put it back together, updated to the latest BIOS and it was ok for a few days.
It’s now doing the same again.
Any ideas please ?
Thanks
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
5 Antwoorden
Filteren op:
Het nuttigste antwoord
Fan needs to be replaced, had one that would intermittently display that error and replacing the fan fixed it. This is on a HP TPN-C125 general model.
Was dit antwoord nuttig?
Score 2
Hi @netdudeuk
I’ve fixed with this issue a lot in the past with HP. The bios on many older models can get stuck and will need a CMOS battery reset. You can simply remove the button battery and re-install, but I would recommend replacing it. It would be a good idea to complete a BIOS update as well if one it available.
If this issue continues even after the battery is reset, it may be a sign of BIOS failure.
Score 1
Have you tried blowing the dust out of the fan? Too much dust can make a fan under-perform , which will cause a 90B error.
Score 1
Afbeelding
Hi
I removed the heat sink and fan and there wasn’t a speck of dust. I applied thermal compound and re-fitted it.
I replaced the backup battery.
The laptop started up ok many times.
The error had returned this morning though.
I turned the laptop onto it’s side and blew into the vent. It then started up ok again !
I wonder if there are certain positions where the fan cannot start ?
There are plenty of replacement fans for HP laptops on eBay UK but it isn’t clear if they would be compatible.
For example, this looks similar.
https://www.ebay.co.uk/itm/HP-17-X-Fan-1...
I have attached a picture of mine.
Thanks
BTW, thanks for the previous replies.
Voeg je antwoord toe
Steve zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 28
Altijd: 3,968
