Ga door naar hoofdinhoud
De Sony α6500 is te herkennen aan modelnummer ILCE-6500. Het is een spiegelloze digitale E-mount camera met een APS-C-sensor. De Sony α6500 werd uitgebracht in november 2016.
Sony 6500 Base Damaged
The Base of my Sony 6500 was damaged in that a tripod screw broke inside the camera body and now the camera cannot be used on a tripod as the screw cannot be removed. Is it possible to have that bottom OR the complete outer camera replaced
Is dit een goede vraag?
1 Opmerking
I'm not sure how different the models are but here is a disassembly video of the A6000. Hope it helps!
https://www.youtube.com/watch?v=y3CCJtD0...
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Hey Douglas,
I had a similar thing happen with my a6000 a while ago. You could opt to replace the outer housing, but depending on how well the tripod screw is lodged, it could be removable with no disassembly. I covered the bottom with painting tape and made a hole in the tape where the screw is is. I then used a small bolt about the size of the hole, put a small dab of glue on it, and let it set. Once it set for a long time and hardened, I simply twisted it out.
Hope that works for you, best of luck!
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Douglas Quick zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 28
Altijd: 637
