Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Vragen Bekijk alle
Is battery adhesive necessary?
After performing a screen and battery replacement, I realised I forgot to adhere the new battery down to the casing. However, I've not notice anything adverse since doing it. Should I have stuck the new battery back down? What is the consequences of not adhering the new battery down?
Apologies, my Google Fu has failed me today.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
It is not necessary,but recommended. It can rattle around a little bit and could bump against the inside of the screen. Really,it would be annoying to have it rattle around,and it could bang the screen. Overall,you definitely can get by just fine without replacing it.
Was dit antwoord nuttig?
Score 2
Need adhesive. The cable from the battery will get damaged overtime. Even using scotch tape in a loop is better than nothing to stick both sides.
Score 1
Voeg je antwoord toe
Casey zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 35
Altijd: 587
